Filling in round reflectors
StienbargerR
PostPosted: Mon Jul 03, 2006 9:39 pm    Post subject: Filling in round reflectors Reply with quote
hey everyone,
What is the best way to fill in the reflector holes? I want to get rid of both the front and rear round reflectors. Should I use bondo, or Fiberglass? I am having my car painted soon, would it just be better to have a shop do it for me?
Ryan
1978 924 NA
-250lb lowering springs, Euro Pistons
Vince Ponz
PostPosted: Mon Jul 03, 2006 10:41 pm    Post subject: Reply with quote
Weld the first and fill with either glass or bondo. Trust me on this one.
I did both on my two cars.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
StienbargerR
PostPosted: Wed Jul 05, 2006 4:11 am    Post subject: Reply with quote
thanks
Ryan
1978 924 NA
PostPosted: Thu Jul 06, 2006 7:49 pm    Post subject: Reply with quote
I didnt weld i just filled & its held up for a couple years now.
924SSilver
PostPosted: Tue Jul 11, 2006 1:08 pm    Post subject: Reply with quote
I say keep 'em!
But if you arent going to weld, dont just use plastic filler
You might be able to get away with sanding the area clean of paint and use long strand fiberglass filler, making sure you extrude some of the slop thru the holes. You might even want to perf a few more holes to give it more to grab. It holds pretty well, but it's no fun to use. It's like brillo pads filled with axle grease!
However,if you can, weld it.
I still say keep em....
TheFuzz89
PostPosted: Wed Jul 12, 2006 3:23 am    Post subject: Reply with quote
I'm actually eliminating mine as we speak. I just used bondo, but put tape over the back of the holes to keep the body filler where it needs to be. Should be all it needs really.
1977 Porsche 924
924SSilver
PostPosted: Wed Jul 12, 2006 9:14 am    Post subject: Reply with quote
Watch for bumps! Youll be seeing your bondo plugs in the rear view mirror!
Pca944
PostPosted: Fri Jul 14, 2006 3:34 am    Post subject: Reply with quote
Photos!
I've never been a fan of the reflecters, they look like they belong on a bike. Still, considering how small 924s are I'm not sure how safe it would be driving around at night.
1986 944 | 1978 924 (FS) | 1982 931 | 1980 931
TheFuzz89
PostPosted: Sat Jul 22, 2006 1:43 am    Post subject: Reply with quote
Just got my car back from paint and thought I'd post a picture of where my side markers used to be.
1977 Porsche 924
gohim
PostPosted: Sat Jul 22, 2006 1:51 am    Post subject: Reply with quote
Bondo (plastic body filler) is porous and absorbs water like a sponge. If you live where cars rust, if you use/used bondo to fill in the marker holes or repair a dent using the old drill and fill method, what you are doing is making the perfect home for rust to hide, and take hold in your fenders.
Welding the holes closed and undercoat is the only long term way to close off the marker holes or repair damage.
seanski44
PostPosted: Sat Jul 22, 2006 1:53 am    Post subject: Reply with quote
Pca944 wrote:
...I'm not sure how safe it would be driving around at night.
we manage in the rest of the world OK
mind you all the cars are small here!
1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD
StienbargerR
PostPosted: Sat Jul 22, 2006 2:54 am    Post subject: Reply with quote
So you all confuse me
Some of you say DO IT! and others say that bondo is gonna fall out if I hit a bump....or it will rust...
So what if I use fibre glass? I want to get rid of those dumb things, but I want to avoid rust. I think that they look really nice gone.
Whats the verdict?
Ryan
1978 924 NA
PostPosted: Sat Jul 22, 2006 3:05 am    Post subject: Reply with quote
I say body filler should be fine if done right - regular or fiberglass-reinforced body filler.. It should be applied directly to rough sanded clean bare metal or over epoxy primer within the time limits specified by the manufacturer. Apply when humidity is low and keep it dry until primered and top-coated - and paint over all exposed filler including the back of the panel so it can't absorb moisture.
tux
PostPosted: Sat Jul 22, 2006 4:21 am    Post subject: Reply with quote
I think its one of those personal taste/budget things Ryan.
Sure if you have the equipment/expertise/budget then welding in sheet metal is the way to go. It will last longer in the long run and will be stronger.
If you cannot afford the welding then go with fibreglass/bondo. Some will consider it to be a bodge and it probably won't last as long overall, but if its done properly and you don't do "contact sports" with your car then it shouldn't be a problem.
Pete
Merlin Guards Red 1985 N/A
StienbargerR
PostPosted: Sat Jul 22, 2006 5:07 am    Post subject: Reply with quote
Ok,
thansk guys. I think I will go ahead and fill them in before I paint.
Would it be best to do it in an airconditioned garage, and leave it there till it is cured?
Ryan
1978 924 NA
