Adjusting lifters, parts question.
WhoDak
PostPosted: Fri Oct 07, 2005 7:17 am    Post subject: Adjusting lifters, parts question. Reply with quote
I'm going to adjust my lifters this weekend if I can get a hold of the oiler elbow and new cam seals. What part number is the oiler elbow, is it that little small piece called an adapter on the cam pulley end of the oiler tube? And is it nessicary to install new gaskets when pulling the cam cover, my engine was rebuilt about 10,000 ago. Thanks.
And if I've got another person handy to take pictures I'll try to put a step by step with pictures up for the new site too.
Mike
'82 924 N/A
'91 Toyota Pickup SR5 4x4 Xtra cab
Chrenan
PostPosted: Fri Oct 07, 2005 8:22 am    Post subject: Reply with quote
It is actually called an "Oil Tube Connector". It should be a couple of dollars at the dealership. The part number is:
052 115 707
I would definitely replace the cam cover gasket while you are in there, it can't hurt. Part number (I think):
060 198 025 1
Gram
PostPosted: Fri Oct 07, 2005 8:51 am    Post subject: Reply with quote
Yep..part numbers confirmed, altho the timing cover gasket was 060-198-025 (no -1).
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
Gram
PostPosted: Fri Oct 07, 2005 8:52 am    Post subject: Reply with quote
BTW..they called the plastic elbow a 'cam oil line adaptor'.
WhoDak
PostPosted: Fri Oct 07, 2005 9:17 am    Post subject: Reply with quote
Ah ok, I stopped at the Porsche shop in my town and we looked it up in the book, I went ahead and ordered the "adapter" and the gasket. Thanks guys.
Mike
'82 924 N/A
