cutout under electrical load
horsleyflyer
PostPosted: Thu Sep 29, 2005 10:38 pm    Post subject: cutout under electrical load Reply with quote
hi folks,
I have a 1984 2.0l 924. It starts and runs fine until I put any heavy electrical load on it [ ie switching on the headlights - it's fine on side lights]. I've recently had trouble with the number 2 fuse on the additional fuse board [ fuse overheating ] which i corrected by putting a modern blade fuse and fuse holder in to replace the old one. Any ideas please?
Tigger937
PostPosted: Fri Sep 30, 2005 2:09 am    Post subject: Reply with quote
Yeah, I've been having electrical problems too. Hot F2 fuse on the additional fuse board (fuel pump fuse), hot fan relay (Relay I) and fuel pump relay problems (Relay II). Haven't had any problems with headlights though. I removed the fuse/relay panel and additional fuse panel and found several wires that had evidence of overheating near the panels..............ie., browned insulation, hardened wires, some corrosion, etc. I decided it was time to look at replacing the fuse/panel, additional fuse board and overheated sections of wire. I was afraid the fuse panels were going to be horribly expensive. I called Sunset Porsche in Oregon, who advertises OEM parts at cost + 15% and to my surprise, the main fuse/relay panel was only $83 usd and the additional fuse panel only $8.50 usd................not too bad! So they're on order. Also, found that EagleDay.com (someone here on this board suggested them) has the OEM electrical connectors and wires too.
Now the question becomes, what caused the overheating of the wires. Was it just corrosion over time, or was it overloading in the circuit caused by deteriorating components? I am suspecting both since it is well known the fuel pumps and cooling fans can have excessive current draw and yet appear to be functioning OK, ie., they don't just fail completely, at least not initially, they can gradually get worse over time. Quite possibly, this is related to accumulation of dirt/contaminants. As the current draw increases, heating in the wiring, relays and fuse/relay panels goes up leading to increased resistance and components not performing to full specification. It's kind of a cascading effect. At least, this is what I think appears to be happening. One must keep in mind these cars are 20+ years old now.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
PostPosted: Fri Sep 30, 2005 9:21 am    Post subject: Reply with quote
Bad grounds add resistance to the circuits which increases the amps that the wires must carry.
Tigger937
PostPosted: Fri Sep 30, 2005 3:29 pm    Post subject: Reply with quote
At first Paul, when I read your post, I thought NO WAY!!! For a given voltage, a higher resistance always results in LOWER current. But after thinking about it for a while, you may be on to something. With a bad ground in one circuit, the return current for that circuit could easily get diverted through the return of another circuit thereby increasing the current in that circuit, even to the point of overloading it. The return current will always seek out the lowest resistance path back to it's source, the battery neg. connection, even if it has to go through another circuit to get there. It appears this may open up the possibility of another failure mode. Hmmmmmmmmm.
1981 931 (Concours)
horsleyflyer
PostPosted: Fri Sep 30, 2005 7:48 pm    Post subject: cutout under electrical load Reply with quote
Hi and thanks for gettiong back to me! I spoke to my mechanic who advised me that the old stlye fuses build up resistance between the fuse and holder as the fuse holder becomes weaker. He lent me a blade fuseholder with two wires and crocodile clips on the end advising me to bridge the original fuse with this set-up, hey presto the fuse didn't heat up! I've now replaced the original fuse and holder with blade types and this has cured the heat problem- the engine still cuts out when the headlights come on but I guess the fuel pump relay must have been fried when the fuse was arcing and I've ordered the new one. I'd better come clean and tell you that I live in the Uk but WILL order parts from the US if they are easier to obatian. Once again many thanks for your help and will advise about the headlights/relay prob.!
PostPosted: Sat Oct 01, 2005 10:21 am    Post subject: Reply with quote
Think of it this way:
Bad grounds add resistance to the circuit, thus increasing the total resistance of the circuit, thus more amps and heat.
PostPosted: Sat Oct 01, 2005 10:31 am    Post subject: Reply with quote
BTW electrons travel from the negative post of a battery to the positive post.
http://www.pbs.org/wgbh/amex/edison/sfeature/acdc_insidebattery.html
PostPosted: Sat Oct 01, 2005 10:45 am    Post subject: Reply with quote
Unless you are talking about a 924 battery which generally defies all known laws
PostPosted: Sat Oct 01, 2005 11:01 am    Post subject: Reply with quote
The British had it right in the 60's, they grounded the positive cable!
Tigger937
PostPosted: Sat Oct 01, 2005 11:59 am    Post subject: Reply with quote
Agreed. Positive current flow convention is in the direction of "hole" flow, from positive terminal thru the circuit to negative terminal.
1981 931 (Concours)
dpw928
PostPosted: Sat Oct 01, 2005 11:08 pm    Post subject: Reply with quote
The 924 needs at least 10 volts in the primary circuit to see 5 volts at the coil. If it drops below 5 volts your engine will cut out or quit. It appears the voltage is dropping when the alternator has a higher load with the headlights. This is usually a symptom of one or more bad diodes in the alternator. Another possibility is the battery is shorting at a high load. Most autoparts stores can test for these problems.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
Tigger937
PostPosted: Sun Oct 02, 2005 3:33 am    Post subject: Reply with quote
Interesting. What sets the lower 5 V limit? Is it the fuel pump relay rev limiter circuit?
1981 931 (Concours)
dpw928
PostPosted: Sun Oct 02, 2005 4:52 am    Post subject: Reply with quote
The current comes from the 15 post on the ignition switch, runs through a resisted wire and on to the coil. Without at least 5 volts the coil won't charge up enough to generate a spark.
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Sun Oct 02, 2005 5:47 am    Post subject: Reply with quote
Found this:
You are right, there is some confusion about the direction an
electric current is flowing.
When electricity was discovered, nobody knew how it works and
electrons were unknown. So the scientists just defined one of
the poles as "positive" and said that the current is flowing
from positive to negative. That still is the definition of an
electrical current's flow direction.
However, later scientists discovered that in most (but not all)
materials current is carried by negatively charged electrons,
which travel from negative to positive. The electron flow is
thus opposite to the current flow.
In some materials (e.g. electrolytic solutions) the current is
carried by positive ions, which travel in the current's direc-
tion. And in semiconductors there can be currents of negative
or positive carriers, depending on the doping.
PostPosted: Sun Oct 02, 2005 5:51 am    Post subject: Reply with quote
Another:
The direction of electron flow is from a point of negative potential to a point of positive potential. The direction of positive charges, or holes, is in the opposite direction of electron flow. This flow of positive charges is known as conventional flow. All of the electrical effects of electron flow from negative to positive, or from a high potential to a lower potential, are the same as those that would be created by flow of positive charges in the opposite direction; therefore, it is important to realize that both conventions are in use, and they are essentially equivalent. In this manual, the electron flow convention is used.
