coolingmist water injection
cleethorpes
PostPosted: Mon Aug 01, 2005 8:04 am    Post subject: coolingmist water injection Reply with quote
has anyone here used or know of anyone using a cooligmist system. They seem to offer similar sytems to those of aquamiist, but for around half the price.
'24 turbo with dodgy gt bodykit......needs a new home
cleethorpes
PostPosted: Tue Aug 02, 2005 7:08 pm    Post subject: Reply with quote
so no-one has used one of the coolingmist systems?
I've found quite a lot of threads regarding fitment to SRT's whatever they are? and the concensus seems very good. I think these cars run much higher boost than us and I'm a bit stuck as to which unit to get. They do 60 psi, 100psi and 150psi pumps and variuos nozel types (based on expected bhp).
Any help from you guys would be grately appreciated.
J1NX3D
PostPosted: Tue Aug 02, 2005 7:11 pm    Post subject: Reply with quote
i think an SRT is a dodge? maybe a neon?
whatever it is we dont get them here.
you have a site for coolingmist?
'86 944
cleethorpes
PostPosted: Tue Aug 02, 2005 7:15 pm    Post subject: Reply with quote
coolingmist.com
really cheap, and they do dual stage kits to, so you caould have a small jet spray at low boost and high at, well ermmm high boost
ESC944
PostPosted: Fri Aug 12, 2005 1:01 am    Post subject: Reply with quote
You can do your own or buy from them or many others....
Not to compicated to build your own, all you need is the parts and toss it together you can use a hobbs switch set to a specific boost level to trigger the unit, even setup a dual unit for you low boost and high boost setup, so you have one on at low boost then both on a high boost, limit would be capacity of tank/storage unit for water.
Most of these units are just using a sinple RV pump to supply the pressure to the injector.
Hope that helps.
cleethorpes
PostPosted: Fri Aug 12, 2005 5:01 am    Post subject: Reply with quote
how much would a pump cost?
any ideas where theysell them?
numbbers
PostPosted: Fri Aug 12, 2005 10:35 am    Post subject: Reply with quote
My idea for a cheap water injection system is to use the windshield washer tank and pump. You can use the full throttle enrichment switch to activate the pump through a relay. All you need is a spray head, and they are available at Home Depot in the plumbing section, for garden drip systems. Just look for a "mister." You can inject the mist directly into your air box, and that way, you do not have to worry about pressure.
PostPosted: Sat Aug 13, 2005 12:23 pm    Post subject: Reply with quote
What does the water injection sys. do actually..
to a turboed motor.
Kenodog
PostPosted: Sun Aug 14, 2005 3:53 am    Post subject: Reply with quote
cools the intake charge temperature,keeps the T.B. and intake valves clean.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
