dpw928
Posted: Mon Jan 10, 2005 3:24 am Post subject: Conversion of Fuses to ATO or Buss |
I'm sure you all are aware of the corrosion problems with our torpedo type fuses. The problem is really accented on the 928's due to the number (28 on my 7 and location (passenger footwell right under the heater blower). Has anyone found a conversion that is "plug and play" in that it is neat and doesn't create other connection problems?
Attached is one conversion I am trying but once all 28 fuses are replaced the front of the panel will look almost like the back.
78 928 5 sp Silver
78 928 AT Euro Black
dpw928
Posted: Mon Jan 10, 2005 3:42 am Post subject: |
Got it.
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Mon Jan 10, 2005 3:51 am Post subject: |
That 928 fuse panel does look scarey, but the mental image of redoing it looks pretty scarey too. I'd probably just clean the fuse contacts with a small wire brush on a Dremel tool and use contact cleaner, then give everything a coating of dielectric grease to increase the time 'til it needs to be done again. _________________ "..it's made in Germany. You know the Germans always make good stuff."
dpw928
Posted: Mon Jan 10, 2005 4:00 am Post subject: |
Smoothie,
I have to do a quarterly cleanup and at least once a month go through a fuse twisting ritual. The biggest problem is moisture from the heating vent getting on the panel. With the extremely small contact area of the OEM fuses it doesn't take much moisture to cause corrosion. The later 928's were produced with ATO fuse holders to aleviate this problem. Swapping out to a later panel doesn't seem to be the answer as the fuse contact banks were drastically changed in later years.
78 928 5 sp Silver
gohim
Posted: Mon Jan 10, 2005 5:53 am Post subject: |
Some VW Rabbit, Golf and Jetta models use the same exact fuse panel, and models of those cars were converted to "blade" fuses from the "torpedo" fuses in the mid-late 80s.
The VW "blade" fuse panel in the 86 VW Jetta that I am preparing for use as a daily driver looks like it should fit in the same space in a 924. It even uses the same "clip-on" relay sockets at the top of the panel.
I have a spare VW "blade" relay/fuse panel that I bought off eBay for $5 (complete with a set of relays). I got it for the relays and the fuses (cheaper than buying a single relay or set of fuses from the store).
I can take photos if someone is interested, but I haven;t ever posted photos, and don't know how.
Personally, I live in SoCal, and except for seasonal downpours (6-8 inches in the past 24 hours), do not get that much rain, and have never had corrosion problems with the fuses or the relay/fuse panel. |
Posted: Mon Jan 10, 2005 6:15 am Post subject: |
Dennis - I can't see well enough in the pic if you're doing this... -But from that Rennlist Sharkskin link you can see that one end of each of the existing fuse holders can be pulled, revealing a 1/4" male spade connector that you could plug right into. _________________ "..it's made in Germany. You know the Germans always make good stuff."
dpw928
Posted: Mon Jan 10, 2005 7:02 am Post subject: |
Smoothie,
Thanks for the links. I've seen the stabilant data and agree that it would help if it really goes from non-conductive to conductive when charged. Irregardless it is still a patch to the small contact problem. The Wingproducts fuse holders look promising. The other holders that I have looked at had a common power input which would make them useless except for the few fuses connected to the 30 or 15 power source. The biggest problem I see with the remote fuse block is managing the wiring looms to and from the block. There isn't a lot of room between the foot board and the fuse panel.
I did remove the top connector so I could use two .25" female spade connectors on my set up. I had to use some needle nose pliers to "slightly" modify the connectors to get them snug.
Thanks again,
78 928 5 sp Silver
Posted: Wed Jan 26, 2005 7:39 am Post subject: |
Here's the VW fuse panel that gohim mentioned above (each pic shows the VW panel at top and the 924 panel below) (click each for larger pics) -
<click for fronts>
<click for backs>
| gohim wrote: | The VW panel is the same width, the same depth, and a little taller in height with the second row of relay sockets builtin. But by the time the second row of relay sockets is added to the 924 fuse panel, it is actually taller than the VW panel. the VW panel has the molded pattern above the second row of relays so a third set of relays can be attached on top, the way the second row of relays is normally attached to the 924 relay panel.
The VW fuse panel uses different plugs than the 924 fuse panel, so to use a VW panel, the wiring harness plugs would need to be cut off of the VW wiring harness, so the plug sockets could be reused (release the pins from the 924 plug sockets, as the pins are the same as those used on the VW wiring harness).
The VW fuse panel in the photos was taken from a 89 VW Jetta GLI/16V. |
MunkPuppy
Joined: 02 Jul 2003 Posts: 419 Location: New Westminster, B.C., Canada
Posted: Wed Jan 26, 2005 6:12 pm Post subject: |
you nutter, you have the pics linked as text files... however, if you save the file to disk, and change the extension to .jpg rather than .txt, the pictures show up just fine
I'm such a geek  _________________ '80 931 FOR SALE
"It's a shame that stupidity isn't painful"
-Anton Szandor LaVey |
gohim
Posted: Wed Jan 26, 2005 7:23 pm Post subject: |
thanks for posting the photos for me Smoothie....
As you all can see the VW fuse/relay panel is very close to the 924 part.
The retaining screw bracket at the bottom is in exactly the same spot, and are the "pins" on the sides that the panel is "hung" on. So the VW panel would be a "drop-in" replacement for the 924 panel.
The rearranging the wires in for the vw socket plugs would be a challenge, but I expect that it could be done in less that a day, and probably less than 1/2 a day if the wiring harness was off the car where the person doing the work had easier access. |
Posted: Thu Jan 27, 2005 2:40 am Post subject: |
No prob, glad to help.
The actual rewiring job would be simplified if you scribble down a cross reference of the from-to connector and pin numbers beforehand-
P924........VW
A12..........C3
B5............B7 , or whatever, etc.
MunkPuppy - I change the extention to .txt because Geocities doesn't allow direct links to display .jpg photos. With .txt, the pics display directly in posts - apparently not for you, but they do for me in IE and I'm assuming it works the same for anyone else using IE. I think it used to work for me in Netscape also. Maybe some browsers handle it differently? What browser are you using? _________________ "..it's made in Germany. You know the Germans always make good stuff."
Alex Roy
Joined: 03 Nov 2002 Posts: 694 Location: Springfield Oregon USA
Posted: Thu Jan 27, 2005 3:50 am Post subject: |
ut-oh, I think Smoothie one-upped your geekdom with his geo-cities hack.
You nerd-foo is very strong grass-hoppa! |
