Measurements for vacuum line replacement
PostPosted: Tue Jun 23, 2009 3:08 am    Post subject: Measurements for vacuum line replacement Reply with quote
Since this has come up a few times, and I never can find the reference when I need it, I'm posting here for posterity's sake:
This is what I ordered when I replaced the vacuum lines on my 941 with silicone replacements from Hose Techniques:
  • 20138-001-110 SVH by the foot 3.5 mm Inside Diameter SpecJetBlack: 10 feet
  • 20500-001-110 SVH by the foot 12.7 mm Inside Diameter JetBlack: 6 feet
  • 20750-001-110 SVH by the foot 19.0 mm Inside Diameter JetBlack: 3 feet
  • 70001-603 Accessories Super HoseCutter
  • .56F.075-356-110 Silicone Turbo Hose-90° Elbow-JetBlack Gloss Finish
FWIW, I should have order probably double the 12.7mm, as I didn't have enough to replace the charcoal canister lines.
Related discussion: http://www.924board.org/viewtopic.php?p=210543#210543
agfisher
PostPosted: Thu Jul 02, 2009 11:46 pm    Post subject: Reply with quote
Would these be the same quantities for a 77 NA??
1977 924 N/A Martini Edition
agfisher
PostPosted: Tue Jul 21, 2009 8:57 am    Post subject: Reply with quote
Bump
PostPosted: Tue Jul 21, 2009 9:20 am    Post subject: Reply with quote
Nope. Let me see what I ordered for my 81 NA...
...the archives say 10 feet of 10mm and 10 feet of 4mm. Apparently, I didn't replace the really large 19mm stuff with silicone, I think I just used some standard heater hose that was close enough. Not sure, I can't check as the car is not at the house presently.
agfisher
PostPosted: Wed Jul 22, 2009 3:52 am    Post subject: Reply with quote
OK, thanks. I tried doing some searches and all I could find were 931 and 944 info (using google too). Has anyone listed and/or mapped out the exact hoses that should be replaced. I just want to make sure I'm replacing everything that needs to be replaced and not replacing something that shouldn't be.
Adam
agfisher
PostPosted: Wed Jun 30, 2010 11:13 am    Post subject: Reply with quote
My apologizes for resurrecting an old thread but had a couple of questions.
Above you have stated 10 ft of 4mm and the kit here (http://www.lindseyracing.com/LR/Parts/944VACUUMLINE.html)mentions 5/32" (3.9 mm) hose. I've seen other places mention they used 3mm. Any preference for the NA.
Anyone out there do a vacuum hose replacement on their NA and have any additional ideas on what they used?
PostPosted: Fri Jul 02, 2010 8:58 am    Post subject: Reply with quote
AutoHausAZ has the 3.5 stuff for $4.73/m.
931Owner
PostPosted: Sun Jul 04, 2010 12:34 am    Post subject: Reply with quote
Nice, I was just about to ask which size hoses are needed.
should this be a sticky?
1980 Turbo
PostPosted: Thu Jul 08, 2010 5:50 pm    Post subject: Reply with quote
hey Rasta is this the hard vaccum hose, or the very flexible silicon...
I definately prefer the harder stuff as some of the silicon stuff colapses under high vaccuum. It also clamps down better and doesn't split.
PostPosted: Fri Mar 11, 2011 3:48 am    Post subject: Reply with quote
Flexible. Just got rid of my small cloth covered hoses (and those flipping clamps). . .what a pleasure.
