EGR Line broke on the Header
PostPosted: Fri Jul 06, 2001 1:29 am    Post subject: Reply with quote
Email: Skyking1@bright.net
Date: 06 Jul 2001
Time: 01:29:30
Vaughan
How did you do
at Mid Ohio last weekend?
Line broke on off of head pipe
Can I put it and remove the egr line and will it be ok
or do I buy a new header pipe and line or what
What would be a good fix
Dave
PostPosted: Fri Jul 06, 2001 1:34 pm    Post subject: Reply with quote
Email: vscott77@nospam.hotmail.com
Date: 06 Jul 2001
Time: 13:34:41
Hey, did pretty well...
first race started 28th, finished 26th (out of a field of 31 ITA cars)
Second race, started 26th, finished 21st... heavy attrition...
Car's fine, no major issues or damage... well, actually, have to replace a driveshaft as one CV boot got cut, have to replace the waterpump as I smoked the bearing on it due to overtightened alternator belt, have to re-weld the spherical bearing insert in my A-arms as a weld snapped loose, and I have to corner-weight the car (then realign it) to get rid of a bit of wedge that's currently there, to improve the handling...
I also have to switch that cam key around, to advance the cam 4 deg instead of retard, get the power working down lower... wasn't happy with the way I ran it at Mid-O...
I don't quite understand your question - what line is snapped? Please restate...
PostPosted: Fri Jul 06, 2001 7:40 pm    Post subject: Reply with quote
Email: porsche
Date: 06 Jul 2001
Time: 19:40:35
Thats must be some fun stuff ... there racing in the thick of ot with yer 924 just you and porsche
... I admire that , thats it..
PostPosted: Sat Jul 07, 2001 12:28 pm    Post subject: Reply with quote
Email: 924martinirossi@email.msn.com
Date: 07 Jul 2001
Time: 12:28:32
Mu Martini had a boken EGR pipe (untill Vaughan sent me a replacement). Cut the pipe off and slide the giant nut off. I then stacked some pennies in it and globbed hi-temp silicone in it. Screw it back on and viola!
You will bave to make a block off plate to cover the opening when you remove the EGR valve assy on top.
Michael
