Clutch getting stiff
PostPosted: Wed Jul 04, 2001 5:29 pm    Post subject: Reply with quote
Email: swicks@motorpics.co.za
Date: 04 Jul 2001
Time: 17:29:12
My clutch is becoming stiffer each week. It is worse when the car has been parked all day (or night) and it eases a bit as it is driven.
Does anyone have any ideas why this is happening? I don't want to pull the clutch out.
Cheers
PostPosted: Wed Jul 04, 2001 10:28 pm    Post subject: Reply with quote
Email: Peter@planb.net.au
Date: 04 Jul 2001
Time: 22:28:07
Steve,
is it a cable or hydraulic activated clutch?
Peter in AU.
PostPosted: Thu Jul 05, 2001 12:26 am    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 05 Jul 2001
Time: 00:26:26
if its cable the sheeth is probably in need of some oil (new cable)
PostPosted: Thu Jul 05, 2001 5:15 am    Post subject: Reply with quote
Date: 05 Jul 2001
Time: 05:15:15
Thanks, It is cable - I'll try lubing it as it does feel a bit scratchy as wel. Better still, I might even replace it before it breaks!
PostPosted: Thu Jul 05, 2001 5:57 am    Post subject: Reply with quote
Email: nidge22@hotmail.com
Date: 05 Jul 2001
Time: 05:57:37
My clutch was extremely stiff, I replaced the cable and it has been fine since.
PostPosted: Thu Jul 05, 2001 10:18 am    Post subject: Reply with quote
Date: 05 Jul 2001
Time: 10:18:39
replace the cable.
Basically, it's coming apart which is why it's stiff and probably, as nidge says, feeling a bit "scratchy".
Mine was exactly the same a couple of months ago, stiff and scratchy, and a new cable made all of that (and the rash) go away.
Sorry, couldn't help myself. I'm trying really really hard not to work in a line about the heat in South Africa.
Anyway, just replace the cable.
Peter in Sydney AU.
No longer stiff and scratchy since they decided to have winter.
PostPosted: Thu Jul 05, 2001 12:14 pm    Post subject: Reply with quote
Date: 05 Jul 2001
Time: 12:14:17
it was 30 celsius yesterday in edmonton alberta peter, thats about as hot as it gets here just so you guys know.
PostPosted: Thu Jul 05, 2001 12:30 pm    Post subject: Reply with quote
Email: porsche
Date: 05 Jul 2001
Time: 12:30:53
I had 1 break as I was sitting at the stop sign broke the plastis tip off that slips over the end of the clutch pedal..Replacings a piece of cake
