Wiz-PORSCHE-924
Joined: 06 Nov 2002 Posts: 214 Location: Douglassville PA
Posted: Sat Nov 29, 2003 1:45 pm Post subject: A Good Adhesive FOr my Interior |
| Whats is the best Spray Adhesive for the interior? I need to glue down the carpet on the drivers side, and the eyesore in the back where the trim came off. |
Posted: Sat Nov 29, 2003 2:20 pm Post subject: |
don't know about spray adhesive but the best stuff for gluing trim to painted matal is 3M 08001 Weatherstrip adhesive (gorilla snot). It's a bit messy but it's the best there is. _________________ 1979 924 (Gone to a better place)
Neil924
Posted: Sat Nov 29, 2003 9:01 pm Post subject: |
| How about plastic to plastic? No paint. |
CBass
Posted: Sun Nov 30, 2003 6:20 am Post subject: |
The best spray adhesive is the 3M stuff, it'll hold very well, you just have to be sure to spray enough on there, until both sides look really wet. _________________ '81 931 in various states of assembly |
Wiz-PORSCHE-924
Posted: Sun Nov 30, 2003 11:26 am Post subject: |
| How about something for a split dash right above the speaker? |
CBass
Posted: Sun Nov 30, 2003 1:11 pm Post subject: |
Well, there are dash covers, or Joe's technique of sanding and painted the dash, filling the cracks with fiberglass resin and bondo.
Or you could replace it with a better condition dash, but that means $$$ _________________ '81 931 in various states of assembly |
Ordrune
Joined: 29 Nov 2002 Posts: 40 Location: Sydney, Australia
Posted: Sun Nov 30, 2003 5:48 pm Post subject: |
Sikaflex works a treat.
You can also use it to glue the door windows into their mounts. I did mine last night and is now perfect. _________________ '79 924 supercharged,intercooled |
-nick
Posted: Tue Dec 02, 2003 1:30 am Post subject: |
I've been using the 3M stuff, it has the identical consistancy of the factory stuff. You just have to make sure you keep some pressure on the area to be glued while it's drying. It's working great so far. Even with the ill-fitting PartWerks carpet set I've got.
-nick |
