oxigen sensor
Guest
PostPosted: Sun Jul 01, 2001 5:53 pm    Post subject: Reply with quote
Email: matiasortiz@infovia.com.ae
Date: 01 Jul 2001
Time: 17:53:58
Hi, everyone, nice board you have here... I have a question for you people, I own 1981 924 turbo and I have problems with my oxigen sensor and here in Argentina is very dificult to find a new one, but there are a lot of 80´s used bmw´s, do ypu know if there is any bmw model with the same sensor?? And my other problem is that sensor wire has been cutted, does this need any kind of special wire?? , and also want to know where is the #### control unit?, I cant find It....
Thank´s for all to the 924 fan´s.
Guest
PostPosted: Mon Jul 02, 2001 4:31 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 02 Jul 2001
Time: 16:31:34
Hey, no #### on this board. Virtually any one wire 02 sensor will work. Just splice the wire either using a splice connector or by soldering. Do not just twist the wires together. The connection will build up resistance, and the voltage used is so small that the resistance will cause an error in the reading. You will find the control box under your steering column.
