I think I found my Code !!
Wiz-PORSCHE-924
PostPosted: Tue Nov 04, 2003 11:59 am    Post subject: I think I found my Code !! Reply with quote
I think I found my engine code. But does this sound like one ?
XV C 007 365
dpw928
PostPosted: Tue Nov 04, 2003 12:09 pm    Post subject: Reply with quote
Believe the "VC" identifies it as a 1980 or later US,Canadian or Japanese engine.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
Wiz-PORSCHE-924
PostPosted: Tue Nov 04, 2003 12:13 pm    Post subject: Reply with quote
Hmm Really Because mine is a 78 924
dpw928
PostPosted: Tue Nov 04, 2003 12:36 pm    Post subject: Reply with quote
78's should have an XG or XE (49 states or CA) code. Engine swap?
Dennis
81 931 5 sp
78 928 5 sp Silver
gohim
PostPosted: Tue Nov 04, 2003 1:54 pm    Post subject: Reply with quote
No such thing as a "XVC" engine code.
The mechanical stamping of the engine codes is not perfect.
More than likely, what he has a European Spec. (XK or XJ) engine with poor stamping.
XV and XJ, could look very close. And I would guess that the C is actually the number 0.
CMXXXI
PostPosted: Wed Nov 05, 2003 5:06 am    Post subject: Reply with quote
Take some fine sandpaper and lightly sand the surface where the code/serial number is to remove any surface corrosion and junk that may have accumulated on the stamping. Wipe off the sanding residue, then mark it with some chalk, then wipe it again. The chalk will fill in the writing and the letters/numbers should be very legible now.
'79 Eurospec 931
Neil924
PostPosted: Wed Nov 05, 2003 5:14 am    Post subject: Reply with quote
What are you, a spy?
CMXXXI
PostPosted: Wed Nov 05, 2003 5:20 am    Post subject: Reply with quote
Been watching too many episodes of CSI...
Anyway, using the chalk, fingernail polish or white-out on the timing marks as well (flywheel and camshaft) is a handy thing to do too.
'79 Eurospec 931
Neil924
PostPosted: Wed Nov 05, 2003 5:34 am    Post subject: Reply with quote
So when you look around your house... cool music plays?
Yeah, that's cool!
