kaffine
Posted: Wed Oct 29, 2003 4:37 pm Post subject: in tank fuel pump |
Is the in tank fuel pump needed? The external fuel pump went out and I'm not sure if the internal pump is good or not. I've got the parts to get ride of the in tank pump but I'm not sure how much work it actually does. Thanks. _________________ 80 924
80 931
The best desciption of an atom boils down to something unknown is doing we don't know what.
Sir Arthur Eddington |
Posted: Thu Oct 30, 2003 3:17 am Post subject: |
the intank pump is a low pressure pump 35psi iirc, and all it does is help to eliminate vapor lock in the fuel system on REALLY hot days _________________ 3 928s, |
CMXXXI
Posted: Thu Oct 30, 2003 5:42 am Post subject: |
This has come up before, and it seems that the Board's concensus is that the car will in fact run using only the external pump. I suspect that if you choose to go with only the external pump, you should probably "gut" the internal pump so it won't restrict fuel flow to the external one. The other down-side to not using the internal pump is that it has a fine-mesh screen filter to keep junk out of the external pump (easily fixed by using a small in-line filter though). _________________ '79 Eurospec 931 |
Roger
Joined: 06 Jan 2003 Posts: 1235 Location: Cordova, TN
Posted: Thu Oct 30, 2003 9:18 am Post subject: |
It is my understanding that the internal pump acts to prime the external pump. Since the external pump is lubricated and cooled by the fuel I would say replace the internal pump to be on the safe side. _________________ 1981 924 NA
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs. |
