Battery charging problems
Zak
PostPosted: Fri Oct 24, 2003 12:42 pm    Post subject: Battery charging problems Reply with quote
My alternator is not charging my battery. I had this problem in the past which resulted in taking the alternator in a getting it bench tested. The alternator tested good, so I put it back in the car and took it to a mechanic to have him test the system. When we were playing with the wires, trying to figure out which one goes where, the battery light stopped comming on. It solved the problem, but we wern't really sure what the problem was or how it was solved.
I am experiencing the same problem again, and am not sure what I am looking for to solve the problem. Any suggestions would be helpful.
Thanks,
Zak
jl924t
PostPosted: Fri Oct 24, 2003 3:15 pm    Post subject: Reply with quote
First thing I would check is that your ground wire is secure.
1980 924 turbo
CBass
PostPosted: Fri Oct 24, 2003 4:01 pm    Post subject: Reply with quote
Check all the grounds, they can tend to get a little bad after 20+ years of use/abuse.
My battery ground is chewed up and too short, so I'm going to replace both with GM post style terminals. I've always preferred those connections.
PostPosted: Fri Oct 24, 2003 7:21 pm    Post subject: Reply with quote
theres a wire called the exciter wire could be that.
augidog
PostPosted: Sat Oct 25, 2003 11:22 am    Post subject: Reply with quote
Zak,
I just went through this. Check out the post.
http://www.924board.org/viewtopic.php?t=9016&start=0&postdays=0&postorder=asc&highlight=augidog
