Email: colin@cingram.demo.co.uk
Date: 01 Jul 2001
Time: 05:09:17Jon,
interesting mod., I'm especially impressed that you've retained the pop-up headlight mech.
is the intercooler totally above the water radiator, and is it angled so that the top follows the line of the badge panel? what is the spec of the intercooler - w X d X L , no. of rows, pressure drop at Y cfm?
I see you've partly cut away the front cross member - have you done anything to put the strength back in? a guy ,over here in the UK , doing a GTR replica, cut the whole X member out and joined the longitudinals together with a large diameter tube, mounted well porwrad. his idea worked because the GTR replica front end leaves plenty of space behind it.
regards,
colin
