gwsg
Joined: 03 Nov 2002 Posts: 160 Location: Melbourne Australia
Posted: Mon Oct 20, 2003 9:18 am Post subject: Headlight problem |
My pop up headlights have started acting strange. When you turn them on they open to the full height and then immediately drop back down about 1/2 inch so the beam is aimed only about 4 foot in front of the car. Any ideas what could be causing this? _________________ My 80 924 loves me. |
Which car to buy?
Posted: Mon Oct 20, 2003 9:21 am Post subject: |
This happened to me when I got my car.
There was a wiring problem. A couple of new ground wires and it worked again. |
Posted: Mon Oct 20, 2003 9:22 am Post subject: |
udon the arm coming off motor and raise headlights fully, then reput on arm and lower they should be fine _________________ 3 928s, |
Doodle
Joined: 25 Nov 2002 Posts: 225 Location: Comox Valley, B.C. Canada
Posted: Fri Oct 24, 2003 3:08 am Post subject: |
In tandem with Lizards' suggestion or perhaps a little before trying to move the arm coming off the motor, check to make sure the mounting brackets for the headlight motor haven't loosened. When I re-assembled my car I thought all I had to be concerned with was aligning the headlight covers with the body panels. When I turned on the headlights I discovered the same problem you describe. The lights popped up O.K. but the light beams pointed almost straight into the pavement.
Check to make sure the rubber cap on the stop screw under the headlight housing is making contact with the car body. In my case they were not. The fix was moving the two mounting brackets (there's about a half inch of adjustment) a little further towards the front of the car and then adjusting the arm coming off the headlight motor.
Note that I had completely removed the entire assembly too get the car painted. In your case, unless you've recently messed around with the assembly I would suspect the mounting brackets having loosened before the control arm having moved on the shaft. _________________ Doodle
Pre 77.5 Mars Red |
