shocks and struts
PostPosted: Thu Jun 28, 2001 9:29 pm    Post subject: Reply with quote
Email: porsche
Date: 28 Jun 2001
Time: 21:29:07
what shocks and struts can i put on the 924 from like audi rabbit vw
PostPosted: Fri Jun 29, 2001 8:46 am    Post subject: Reply with quote
Email: vscott77@nospam.hotmail.com
Date: 29 Jun 2001
Time: 08:46:15
The strut tubes are the same for the front of the car; the A-arms are similar but don't necessarily have the mounts for the swaybars.
Buy new struts - the cartridges are the same.
The throttle bodies swap out; get one from a 16V VW or Audi... just look around... the bolt patterns are usually the same.
PostPosted: Fri Jun 29, 2001 12:21 pm    Post subject: Reply with quote
Email: porsche
Date: 29 Jun 2001
Time: 12:21:07
16 valves OK . Thank you. I heard this doesnt change much ...makes for a little quicker
rpm (throttle response) when opened is what I heard.
PostPosted: Fri Jun 29, 2001 9:56 pm    Post subject: Reply with quote
Email: porsche
Date: 29 Jun 2001
Time: 21:56:15
Mine now has Konis i can tell cause there orange
must be special order cause i thought they all came with boge
PostPosted: Tue Jul 03, 2001 7:35 pm    Post subject: Reply with quote
Email: pghiggs@statestreet.com
Date: 03 Jul 2001
Time: 19:35:28
Vaughan,
Is the throttle body the same for the 924 and 931 series one, 1980 model i.e. is the bolt pattern the same for these. as you know the series two 931 had a different throttle body - larger/single round, and I have been told a different bolt pattern i.e. I would also need the intake manifold to make fit - would rather not have to buy the throttle & manifold - what are my options on the throttle body using the series one manifold?
Thanks,
Peter
1980 931 Euro
