Fuel Pump Electrical System
PostPosted: Sat Jun 23, 2001 7:12 pm    Post subject: Reply with quote
Email: ice23_@hotmail.com
Date: 23 Jun 2001
Time: 19:12:58
My 1980 931 keeps burning up fuel pump relays (yes I am using a 931 relay). I seem to have a resistace of about 6 ohms more than the average resistance in the car. About the only other thing I can think of at this time would be to check the ground. Would a loose ground wire behind the dash cause this problem? Also the tips of the fuel pump fuse are burnt black. I would rather rebuild the motor than re-wire this car. What a nightmare!
PostPosted: Sat Jun 23, 2001 9:27 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 23 Jun 2001
Time: 21:27:23
is the pump new? do you know if the pump is drawing OK current?
PostPosted: Sun Jun 24, 2001 3:21 pm    Post subject: Reply with quote
Email: themechanic@talk21.com
Date: 24 Jun 2001
Time: 15:21:33
Remove the fuse and put an ampmeter in its place to check the current draw. then put the ampmeter in series next to the pump. Check the grounds and connections if the current is higher than it should be.
PostPosted: Sun Jun 24, 2001 5:29 pm    Post subject: Reply with quote
Email: eagleman1@navegalia.com
Date: 24 Jun 2001
Time: 17:29:21
Does anybody know if there is a thermostat from other car that fit in the 924 and opens at below temp? I´m from europ.
Thanks.
PostPosted: Sun Jun 24, 2001 5:30 pm    Post subject: Reply with quote
Date: 24 Jun 2001
Time: 17:30:02
Thanks.
PostPosted: Tue Jun 26, 2001 3:29 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 26 Jun 2001
Time: 15:29:34
You can buy a low temp thermostat for the 924 at any autoparts store. No more expensive than for any other car.
