CO adjustment
PostPosted: Fri Jun 15, 2001 11:54 am    Post subject: Reply with quote
Email: vances@mwonline.net
Date: 15 Jun 2001
Time: 11:54:32
Recently I saw a posting here describing how to make CO adjustments using a dwell meter.
It says to adjust the CO until the dwell meter reads 45 degrees. As I turned the adjustment screw
the dwell would increase to about 42 degrees and then decrease again.
I have also seen kits shown that display the O2 sensor output on the dash, I assume that this
is another way of monitoring CO.
My questions are, does anyone know what the output of the O2 sensor is? Is the method
of using a dwell meter looking at the O2 sensor output or something else? Is adjusting the mixture
until the O2 sensor reads 850mA an acceptable method of adjusting CO. Should I forget
about all this do it yourself stuff and just take it to a shop?
