931 hesitates harshly as soon as it hits boost
PostPosted: Fri Jun 15, 2001 7:08 am    Post subject: Reply with quote
Email: gregkilner@hotmail.com
Date: 15 Jun 2001
Time: 07:08:25
931 hesitates harshly as soon as it hits boost. Runs fine if driven gently. When the car hesitates i can hear the fuel pump relay clicking.
Very strainge what would effect the relay like that when the engine is under load on boost????????????????????????????
Greg
PostPosted: Fri Jun 15, 2001 9:00 am    Post subject: Reply with quote
Email: kevrl@globalnet.co.uk
Date: 15 Jun 2001
Time: 09:00:05
Hi Greg,
I had a similar problem and it turned out to be the overboost cutoff switch. This is mounted on the side of the upper pressure duct (The bit with 925 Turbo written on it), To test if this is the problem, connect the connector from the overboost switch to some metal of the engine or run a wire to the -ve of the battery, this will bypass it. Don't drive around to long like this as you could damage your engine.
Good Luck
Kev
PostPosted: Fri Jun 15, 2001 9:04 am    Post subject: Reply with quote
Date: 15 Jun 2001
Time: 09:04:22
daaaa - a slip of the finger ...it has 924 Turbo written on the pressure duct
Kev
PostPosted: Fri Jun 15, 2001 9:39 am    Post subject: Reply with quote
Date: 15 Jun 2001
Time: 09:39:36
Thanks kevin, i will check that out tonight.
Greg
