A/C:  Fix it or Remove it?
PostPosted: Mon Jun 04, 2001 10:22 pm    Post subject: Reply with quote
Email: ricomartinez@yahoo.com
Date: 04 Jun 2001
Time: 22:22:11
Repairing the battery box from the inside got me wondering about the A/C system on my '81. Currently, it is not working (cooling the air) as far as I can tell. Am considering taking it to be diagnosed with an estimate to get it back to new. But if that is too expensive, I'm taking it out anyway.
I was hoping for some help from the list though. When working properly, how well does the A/C system work? If these things don't work well, then I'll just take it out rather than spend money to get it fixed only to blow semi-cool. I do know that the A/C fan is much better than the normal one.
What kinda weight savings can I expect from removing it?
PostPosted: Mon Jun 04, 2001 10:51 pm    Post subject: Reply with quote
Email: l_porsche@hotmail.com
Date: 04 Jun 2001
Time: 22:51:31
70 pounds if you strip all AC off
PostPosted: Tue Jun 05, 2001 7:08 am    Post subject: Reply with quote
Email: http://www.loghomesontario.com
Date: 05 Jun 2001
Time: 07:08:52
The whole idea of airconditioning in a "true wind in your face, water on your head, ride like a truck
sports car" is not on. Plus there's a Green issue and that is; all air conditioners leak bad stuff. My two
shtinking cents worth. dwak
PostPosted: Wed Jun 06, 2001 6:07 am    Post subject: Reply with quote
Email: awilson40@earthlink.net
Date: 06 Jun 2001
Time: 06:07:13
But doesnt do much. On a 90deg day its kicking out 60 deg air from the vents but doesnt have the BTU's to cool the car. I almost never use it, If I were you and its expensive to fix, I would strip it out. About the only time its worth using is on hot, humid nights when there is no sun load on the car.
PostPosted: Wed Jun 06, 2001 6:13 pm    Post subject: Reply with quote
Email: petet@cornelius.com
Date: 06 Jun 2001
Time: 18:13:41
My '79 has air and it works great. I have also converted it to R134a. It blows 42 deg. air on a 90 deg. day.
PostPosted: Fri Jun 08, 2001 5:35 pm    Post subject: Reply with quote
Email: david.c.russell@lmco.com
Date: 08 Jun 2001
Time: 17:35:24
PST. What did you do to convert over? Mine works fine now, and I still have some R32, but I will need to convert over some day. Any loss in performance after the conversion?
PostPosted: Mon Jun 11, 2001 11:36 am    Post subject: Reply with quote
Date: 11 Jun 2001
Time: 11:36:14
I used a kit from a local parts store that contains a can of o-ring conditioner/oil; adapter fittings and a decal. You screw the adapter fittings onto the origional and recharge to 85% of the R12 charge. I've used this kit on 3 cars succussfully. However, on my Caravan the condenser isn't large enough so I only get 50 deg. out of it. I need to change the condenser. R134a needs a larger or more efficient condenser than R12 and the pressures are a little different. The sight glass isn't really useful either. When fully charged, the sight glass looks milky instead of clear. Also, the low side pressure should be 12-20 PSI and the high side should be 200-250 PSI. It is very easy to overcharge R134a so be careful. Also, make sure that you do a thorough job of evacuating before charging.
