Email: jod3511@home.com
Date: 05 Jun 2001
Time: 19:15:39http://porsche924.homestead.com/files/spring_day_924.9.jpg
I cant get the clutch cable to adjust and work (cables loose) at 138 mm loke Haynes says ? (why)
the clutch isnt wore to the limit yet of 8.5 mm
the clutch lever is in the right spot (kind of).It grind when i want to go 1 st or reverse ... is something wore out such as pressure plate or shifter bushings .. Do i have to take some time and adjust everthing. I have to mash the pedal to the floor.. clutch is close to wear limits but not there yet.. changed the oil in tranny its a 5 sp 016z i really think its the clutch any 1 hace these problems before .
