924 Timing Marks
PostPosted: Mon Jun 04, 2001 11:27 am    Post subject: Reply with quote
Email: vances@mwonline.net
Date: 04 Jun 2001
Time: 11:27:21
I was trying to time my '82 924. I noticed only one timing mark on the flywheel and it has
the number 10 stamped directly above it. Is this the mark I should be using? Does the 10
mean 10 degrees advance (or something)?. Should there be another mark?
