INSTALLED A MAF KIT.  WOW!!
PostPosted: Wed May 30, 2001 1:35 pm    Post subject: Reply with quote
Email: Allaces591@aol.com
Date: 30 May 2001
Time: 13:35:05
I just finished installing a hot whire Mass air flow kit from HUNTLY RACING. It is the stage 2 setup. The car runs smoother has better peddle response and it pulls hard from 1000 to redline. I am very happy in the results in this product it cost about $1500 I think it gives like 20 more hp and torque points. It gets rid of the factory air box and old Barn door type air meter. There is a adjustable fuel regulater that comes in the kit it was also easy to install. With the kit you have to run the fuel pressure 6psi higher then stock idle psi (29psi). It is a good investment if you are looking for some more power and quicker acceleration. I also dont have to shift as much when it gets realy hilly. The kit only fits 924S and 944 not sure about anything else. If you have any questions about it e-mail me I would be happy to help.
PORSCHE FAN,
Dave
