5 bolt conversion
PostPosted: Wed May 30, 2001 11:13 am    Post subject: Reply with quote
Email: Eric.Lynch@Itt.com
Date: 30 May 2001
Time: 11:13:50
Just read the 4 to 5 bolt conversion section and it notes that if you use the 944 Master cylinder
you will need to "re-route to have proper proportioning of the brakes front to rear"
Re-route the brake lines. Ok what exactly does this mean and what is involved?
Thanks
Eric
PostPosted: Thu May 31, 2001 8:37 am    Post subject: Reply with quote
Email: vscott77@nospam.hotmail.com
Date: 31 May 2001
Time: 08:37:29
It means you have to change the plumbing of the 924 to a front/rear split (TT split), to match up with the 944 MC. Likewise, the existing hard lines do not match up with the ports on the 944 MC, so you will have to do some more work up there adding lines and/or bending existing lines. Basically, you will have to do some bending and flaring, replumbing the system. Not too hard, just have to have good equipment to get good flares.
PostPosted: Thu May 31, 2001 10:10 am    Post subject: Reply with quote
Email: Eric.lynch@Itt.com
Date: 31 May 2001
Time: 10:10:25
So I could just find a doner 944 and pull the lines off of it?
PostPosted: Thu May 31, 2001 2:56 pm    Post subject: Reply with quote
Email: vscott77@spamless.hotmail.com
Date: 31 May 2001
Time: 14:56:53
Not easily enough - it's easier to build your own lines.
