Email: DirtXpert@aol.com
Date: 26 May 2001
Time: 04:17:19Well I stil have not been able to start the 931. Seemed like I was getting closer but that kinda leveled off.
I put on the CIS module from my 81 931 and that didnt really make a difference. SO i pulled out all the injectors and turned the pump on and watched them spray. Then i asjusted the CIS mixture counter clockwise untill they didnt spray unless the Air meter plate was moved.I used this as the base setting. Then I put the injectors back in and cranked the car and then adjusted the mixture back and forth but now i left it at 1/4 turn Counter clockwise from the base setting and the car seemed to fire twice when I first turned the key, and some times would fire again after another 2-3second of cranking.
Again i had the car runnign before(but was just as hard to start) ive checked EVERYTHING but the WUR.
the only thing i notice is that the CIS module makes a thumping/ticking noise for about 10 seconds after i crank. and the CIS plate has no resistance(like theres no fuel) after i come back to work on the car from the previous day(s).
I just put the tranny in (what a pain) and am about to take it to a shop, but I thought id give it one last shot that someone might think of something.
Thanks
Mike
PS. i still have some copper head gaskets left.
