Brake pedal surge
PostPosted: Tue Mar 14, 2000 8:31 am    Post subject: Reply with quote
Email: azcody@sprint.ca
Date: 14 Mar 2000
Time: 09:31:13
I have recently bought an '87 924S with 150,000kms. One of the snags I have with the car is a "surging" of the brake pedal when the brakes are applied. It is somewhat noticable with light pedal pressure and gets more noticable with an increase in pedal pressure. But (!??!) it doesn't do it all of the time. The left front disc seems to drag more in some spots than others when jacked up and wheel spun. I presume this is a warped disc. The right disc does the same, but is barely noticable. The rear discs seem to be okay. Is the surging most likely to be the disc? Can they be ground or should I just replace them? Could the surging be from any other source?
PostPosted: Tue Mar 14, 2000 10:57 am    Post subject: Reply with quote
Email: vscott39@hotmail.com
Date: 14 Mar 2000
Time: 11:57:04
Turn the rotors if you can; if they're too thin before or after turning, replace them.
V
PostPosted: Tue Mar 14, 2000 9:42 pm    Post subject: Reply with quote
Email: ccole4@neo.rr.com
Date: 14 Mar 2000
Time: 22:42:38
PostPosted: Tue Mar 14, 2000 9:44 pm    Post subject: Reply with quote
Date: 14 Mar 2000
Time: 22:44:24
You might want to check that the front calipers are not sticking. Also I would check that the rear brakes are working correctly. Any of these two conditions can cause the front brakes to be overworked which leads to them overheating and warping.
Date: 14 Mar 2000
Time: 22:44:39
PostPosted: Wed Mar 15, 2000 10:50 pm    Post subject: Reply with quote
Email: 924martinirossi@email.msn.com
Date: 15 Mar 2000
Time: 23:50:47
I agree wit Vaughn. my rotors on the Martini Rossi were at 9.5mm after I turned them and the surging/pulsing was really bad after that. Thake a 12mm open end wrench and try to fit it over the rotors. If it don't fit, good news, you can turn them and it might take care of your problems.
Michael
PostPosted: Wed Mar 15, 2000 10:51 pm    Post subject: Reply with quote
Date: 15 Mar 2000
Time: 23:51:41
I agree with Vaughn. My rotors on the Martini Rossi were at 9.5mm after I turned them and the surging/pulsing was really bad after that. Take a 12mm open end wrench and try to fit it over the rotors. If it don't fit, good news, you can turn them and it might take care of your problems.
Michael
