Email: i97lafr@itek.chalmers.se
Date: 10 Mar 2000
Time: 17:56:32Nice to hear that you got this problem sorted out!
True, it is indeed possible to get a near-perfect timing setting without using the proper stroboscope lamp, although in my experience you may loose a couple of hp by not having the timing 100% correct.
John is absolutely right - the fact that it is a Porsche does not make the ignition system different from other cars, and hence you do not need to consult a Porsche mechanic to set the timing.
/Fredrik
