low rpm hesitation???
Guest
PostPosted: Fri Feb 18, 2000 12:21 pm    Post subject: Reply with quote
Email:
Date: 18 Feb 2000
Time: 13:21:26
I recently bought an 82 924 in almost perfect shape, but at low rpm say 1,500 to 3,000 the car is constantly hesitating. Can anyone give me some type of pointers on what to look at?
Guest
PostPosted: Fri Feb 18, 2000 6:36 pm    Post subject: Reply with quote
Email: webmeister@924.org
Date: 18 Feb 2000
Time: 19:36:46
Jason:
Just do the usual old used car stuff. Get yourself a Haynes manual and check out the ingition first (cause its easier). Check ALL the vacum control and vent hoses. Basically, just replace all of em unless you can tell someone recently did that.
Don't forget your email address please.
John
Guest
PostPosted: Sat Feb 19, 2000 2:00 pm    Post subject: Reply with quote
Email: vscott39@hotmail.com
Date: 19 Feb 2000
Time: 15:00:07
It also wouldn't be a bad idea to replace the fuel filter (use only a good replacement, like Bosch or Mann - the Fram won't necessarily fit) and check all fuel fittings, including those on the injectors, for tightness. I had a deal like this, and found fuel puddling around one of the injectors while the engine was running.
Vaughan
Guest
PostPosted: Wed Mar 08, 2000 2:28 pm    Post subject: Reply with quote
Email: PORSCHE MAN 924@aol.com
Date: 08 Mar 2000
Time: 15:28:50
my 924 revs wicked low when cold and its because of the vacum hoses i just dis conect 1 and it runs buetifull and then when its all warmed up you can plugge it back in and its fine
