Email: revisrose@prodigy.net
Date: 05 Mar 2000
Time: 20:02:38Here is what I have done to my car, in short, yes you can. I ran 205/55VR16 tires on 16X6 inch 928 Style Wheels. This was a stock setup, on some 931's with the M-471 suspension. Tire widths: 205/55 or 205/50 in the front without flairs, any larger in the front may rub, 245/45 in the rear. Some after-market wheel companys still make 4 bolt wheels for the 924. The offset should be approx 52.3mm, or you could just messure the backspace from your old wheels, and ensure the ones you are looking at are the same.
Hope this helps,
Revis Rose
