1983 924 vibrations
DemosT
PostPosted: Fri Jul 11, 2025 2:48 am    Post subject: 1983 924 vibrations Reply with quote
Long story short
Intense vibrations at around 3000 rpm, felt in both the shifter and clutch pedal and droning noise coming from behind (transaxle area) even with the clutch pressed.
Bad engine mounts?
If so where can i find replacement ones?
Thanks
Raize
PostPosted: Fri Jul 11, 2025 5:53 pm    Post subject: Reply with quote
Exhaust touching something.
DemosT
PostPosted: Fri Jul 11, 2025 11:50 pm    Post subject: Reply with quote
Will check when on a lift. I just hope its that and not the clutch or torque tube bearings
