Joao_Portugal
Posted: Sun May 04, 2025 10:13 am Post subject: 924 Turbo | Ignition Problems |
Hello everyone,
I’m reaching out for some help with my 1981 Porsche 924 Turbo (July build), which I own here in Portugal.
I’ve been facing persistent fuel injection problems and have already replaced:
Spark plugs
Ignition wires
Fuel tank
Fuel lines between the tank and the engine
However, a new issue has developed:
The car has trouble starting both when cold and hot.
When cold, it idles but at very low RPM.
In both situations, once it starts, pressing the accelerator at low revs results in no response from the engine.
I would be very grateful if someone knowledgeable could help me diagnose this. Unfortunately, in Portugal it’s quite difficult to find mechanics who are truly familiar with this model and its CIS (K-Jetronic) injection system.
Thank you in advance!
João
Portugal |
Posted: Sun May 04, 2025 3:13 pm Post subject: |
Hey, have a look on my website.
I make EFI kits for the 924 that look very close to the original k-jet.
There are quite a few 924s running my kits all over the world. _________________ Supercharger and EFI kits
https://www.the924.com |
Joined: 29 Jul 2001 Posts: 8943 Location: Royal Oak, MI, USA
Posted: Sun May 04, 2025 9:05 pm Post subject: |
For sure, the first point will be to check the control pressure of the system; this requires a slightly unusual/less common fuel pressure gauge than used for EFI systems, due to the way it hooks up. So you need one that has a valve in it, plumbing designed for CIS systems.
Not sure what the best source for you over there will be, but this is the type I have and am talking about:
https://www.fcpeuro.com/products/fuel-injection-pressure-tester-cta-manufacturing-3850
You can see it not only has a number of adapters to match the fuel system, more importantly it has a valve to stop the fuel flow allowing testing of both pressures...
But I'm sure there's a closer source than the link I posted above, since that's in the US... _________________ Vaughan Scott
Posted: Sun May 04, 2025 9:10 pm Post subject: |
I really recommend reading through the manuals, if you have them, its not that complicated if you read up.on it first, and it makes it easier to diagnos in the correct order.
Any workshop working with older Mercedes, vw, audi, saab, Volvo, Ferrari Porsche etc etc should be able to diagnose the fuelling, its pretty much a similar system in all of them.
Fuel pressure test kit as mentioned above is a key tool for diagnosis. _________________ 1980 924 Turbo
Raize
Posted: Sun May 04, 2025 9:57 pm Post subject: |
Buy a wideband gauge and sensor.
Buy or make a k-jetronic pressure test kit.
Then you will have all the information you need to diagnose.
K-jet is really easy once you have this stuff but if you rely on just randomly replacing parts that’s why people end up saying they hate k-jet and how k-jet is so terrible etc etc. |
Beartooth
Posted: Fri May 09, 2025 3:57 am Post subject: |
I'll just chime in to agree with what others are saying here: the right tools and enough know-how are critical. My 931 sat for around a decade with fuel lines open, so the fuel in the system evaporated and left a lovely coating of gunk in the system. Despite that, a new fuel pump and filter were the only parts I actually needed to get it running as well as a motor with three out of four cylinders in bad shape could. I rebuilt the fuel distributor, but I think that was only necessary because I sprayed brake cleaner in it trying to get the plunger free (not good for the soft parts in it). The two big hang-ups I had getting mine to run right were that the frequency valve wasn't working, and I had to clean out the warm-up regulator a couple times because the gunk in the system plugged it up until it all got worked out. The book on Bosch fuel injection from Bentley publishing was the most helpful thing; the Haynes manual is also helpful, but (understandably) limited in its explanation of the function of the system. _________________ 1980 931 diamond in the rough |
Mclaren924
Posted: Tue May 13, 2025 10:08 am Post subject: |
Raize wrote: | Buy a wideband gauge and sensor.
+1 to this, the wideband is nice to have on really any car but a non intercooled turbo car I would consider this a must have. I would have it wired up off the ignition and have it setup to use like a pressure or temp gauge while you are driving. The harbor freight master fuel pressure test kit is like 90$ and had all the fittings I needed to test my 931 and 924. Like others have said, it's actually really simple when you understand what to test for and what you're supposed to have. Here is a link to the 924 facebook group and go look at the "files" tab, there's a write up called "how to diag a non running engine" by Jim Del Toro and it's one of the best pieces of literature I've ever read regarding diagnosis on these 924 variants. It covers basically everything you could imagine in diag/testing/what your actually looking for.
https://www.facebook.com/groups/2215735825/files/files[/url] _________________ 1980 931 "Salt" Bucket wannabe racer (not started)
1977 924 Slicktop "Pennie" Bucket turned Silver Spoon |
DCM
Posted: Fri May 23, 2025 9:01 am Post subject: Engine stops revving at 5000 RPM |
My '82 931 runs and drives... However, when you rev it to 5000 RPM, it just quits and doesn't rev higher, doesn't die |
