Nzl924
Posted: Sat Apr 26, 2025 8:41 pm Post subject: Control Arm Ball Joint Replacement |
Hi All,
I am restoring the front suspension on my 1981 UK 924 and on pulling it apart it looks like the ball joints on the control arms are not replaceable.
Is there a way you can fit the removable ball joint onto these? Is it as simple as drilling out the rivets or do I need to buy new later model control arms?
Any advice would be greatly appreciated.
Thanks
https://www.icloud.com/sharedalbum/#B1t5oqs3qiD3cr |
Riggard
Joined: 16 Feb 2021 Posts: 77 Location: Heemskerk, Netherlands
Posted: Sat Apr 26, 2025 11:34 pm Post subject: |
Yup, drill them out and put the new ones in using the supplied bolts. |
Joined: 10 Dec 2006 Posts: 967 Location: Noosa Heads QLD Australia
Posted: Mon Apr 28, 2025 9:56 pm Post subject: |
As above, or VERY carefully grind off the head of the rivets and you're ready for paint and new bolted ball joints. _________________ 80/81 932/8 ROW |
