copeina
Joined: 06 Dec 2023 Posts: 21 Location: Calgary, AB, Canada
Posted: Wed Jun 05, 2024 1:04 am Post subject: 1978 Air Flow Sensor Question |
Working back to front on my 78 924 NA and finally spending some time under the hood. Got the ignition all resolved, and got it started for the first time the other night. The fuel gauge and tach even work. Woot!
Along the way, I've found a quirk with the air flow sensor on the side of the air flow meter. I understand these were only on early models and have some relationship with the fuel pump electrical shut off.
With mine, (I've got a 5 pin fuel relay so the pump runs whenever ignition is on), with the air flow plunger in the resting position, the fuel pump works as expected. Manually lifting the plunger immediately shuts off the pump. Return it to the resting position and the pump runs again, so there is obviously a switch of some type in there. Unplugging the sensor turns off the pump. (Anything I've read says the pump should run when that is unplugged) Jumping the pins returns the pump to running and is no longer affected by the plunger position for obvious reasons.
Long question short, what exactly is that thing, and any idea why is it behaving the opposite of expected?
Thank you for any insights. Right now, I'm leaning towards adding it to the "things to delete" list.
/Kris _________________ 1978 924 NA Project |
!tom
copeina
Posted: Wed Jun 05, 2024 6:29 am Post subject: |
| !tom wrote: | | https://www.924board.org/viewtopic.php?p=289747 |
Much appreciated. I'd read that thread 100 times when I was initially deciding how to get fuel flowing. I will be the first to admit I'm not even half decent at reading schematics, so once there was power I never revisited it.
I'll pop the original relay back in and see if that makes things work as they should now that I know the car will actually run with all else in place.
I'm learning. That's what this project was for.
Thanks again,
