1979 coil positive voltage?
anthonimartini
PostPosted: Sun Nov 28, 2021 4:03 pm    Post subject: 1979 coil positive voltage? Reply with quote
im trying to figure out exactly whats goin on with my ignition circuit. can anybody clarify what the coil positive voltage should be? im guessing the clearish wire is a resistor wire. i wired up a bosch red coil using the proper 1.8 ohm resistor not realizing the car already had some resistance. im thinking i can omit the use of the external resistor to use the red coil with my points distributor.
i was getting like 4.5 volts at the coil and boy was it slow. this is freshly built 931 N/A engine that i built so i have no idea what to expect power wise but im pretty sure this is my main hurdle so far. i fired it up for the first time today.
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
anthonimartini
PostPosted: Mon Nov 29, 2021 1:11 pm    Post subject: Reply with quote
nevermind i figured it out. gets battery voltage when not running and cranking and drops to around 10 volts when its running, drops a bit lower when revved. still dont entirely understand the circuit but the voltage works for the red coil with no external ballast.
current:
83 944
87 924S
MOTANUL
PostPosted: Sun Mar 27, 2022 2:01 am    Post subject: Reply with quote
I also have a more complicated question about the Ignition coil:
1. Should I have a Series resistor on my Porsche 931 S1? (5 and 5A in picture).
2. What Ignition coil do you recommend?
The picture is from here: https://nemigaparts.com/cat_spares/pet/porsche/924/4/901050/
sold Porsche 924 NA 1979
MOTANUL
PostPosted: Tue Mar 29, 2022 12:57 am    Post subject: Reply with quote
Doesn't anyone know if I should have ballast resistor / Series resistor on 931 S1 car?
They appear in the book, they appear in the picture - but they do not exist on my car.
I don't think they make any sense on the 931 S2.
Their place should be on 931 S1.
