Strut Brace fitment issues?
MikeDanger
PostPosted: Sat Feb 12, 2022 7:48 pm    Post subject: Strut Brace fitment issues? Reply with quote
has anyone else had this issue? I got a strut brace that came off a 944, but when put on the 924, it doesnt line up, its about 6mm narrower. Debating on how to make it fit. I feel like I have to cut one side of the bar off and reweld the end piece on
PostPosted: Sat Feb 12, 2022 10:50 pm    Post subject: Re: Strut Brace fitment issues? Reply with quote
I bought a strut brace from a 931 (rarely see one that fits). It didnt line up on my car, and it didnt fit over the engine either
Couldnt you just make the screw holes oval to make it fit ?
PostPosted: Sat Feb 12, 2022 10:59 pm    Post subject: Reply with quote
Mike - is your car in the air or on the ground?
PostPosted: Sat Feb 12, 2022 11:23 pm    Post subject: Reply with quote
Good point, i measured mine on jackstands and then on the ground, it differed av couple of mm if i remember correctly. I also jacked it up on the side at 45 degree angle to see if they would move under side load, and there were no measurable movement.
MikeDanger
PostPosted: Sun Feb 13, 2022 3:02 pm    Post subject: Reply with quote
Its on the ground. I doubt the chasis would flex that much, youd probably see that at the side of the hood
MikeDanger
PostPosted: Sun Feb 13, 2022 3:11 pm    Post subject: Re: Strut Brace fitment issues? Reply with quote
you have to go with the bent style, not the straight.
I sorta could but id have to remove more material than id like
MikeDanger
PostPosted: Sun Feb 13, 2022 3:32 pm    Post subject: Reply with quote
MikeDanger
PostPosted: Sun Feb 13, 2022 3:35 pm    Post subject: Reply with quote
PostPosted: Sun Feb 13, 2022 6:45 pm    Post subject: Reply with quote
My bar is very similar, Ive seen it mounted on a 931. I saw it in a "for sale" for a car, and asked if I could buy the bar separately. But obviously my engine sits higher than his, since my boost pipe hits the bar.
In this pic you can see the difference between jackstand (sat there for a year) and dropped down on the wheels.
The bar looks like this, similar to yours.
PostPosted: Mon Feb 14, 2022 2:16 am    Post subject: Reply with quote
So which is to spec and straight, the bar or the car???
MikeDanger
PostPosted: Mon Feb 14, 2022 6:58 am    Post subject: Reply with quote
Well, I pulled it off the 944 it was on, and it fit fine on that.
the side gaps with the hood closed are fine and about "normal"
so are the 924s build slightly different than the 944?
MikeDanger
PostPosted: Mon Feb 14, 2022 9:25 am    Post subject: Reply with quote
Interesting: So apparently, I did have the car jacked up slightly, just a couple inches, but the wheels were still touching the ground, SO I decided to jack it up so the front wheels were fully off the ground. and monitor the Mounting hole Pictured, Noticed no change.
THEN, I fully lower the car and noticed I the hole offest got even bigger, now its about 8mm off.
PostPosted: Mon Feb 14, 2022 8:02 pm    Post subject: Reply with quote
Time for a big lump of 4 x 2 between motor and suspension turret......no marks, no fuss.
You could always relieve the holes...all of them including the strut tower mounting points.
safe
PostPosted: Tue Feb 15, 2022 1:50 am    Post subject: Reply with quote
Can you actually feel any difference with this brace?
Never driven a 9x4 on the track, but maybe the heft in the front makes a difference. I've had them on and off on my old 911 and quite truthfully I can't tell the difference. I have less trunk space with it...
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
MikeDanger
PostPosted: Tue Feb 15, 2022 11:55 am    Post subject: Reply with quote
Well, Ill be honest I didnt think it would make a big difference either, But after seeing how much it moved, just by unloading it, I can imagine, with the side loading and the weight of the engine in a turn, it could be noticeable.
The 911 has even less weight up front, since in a hard turn, the Lump in the rear is wanting to make the tail of the car rotate around.
