Small vacuum lines (pictured)
mattaebersold
PostPosted: Thu Jan 06, 2022 6:59 am    Post subject: Small vacuum lines (pictured) Reply with quote
I took out the small vacuum lines (with the T connectors in them) and replaced the lines based on the layout of the one that came off the car.
Problem is that was so long ago, and now me and the shop are both having trouble figuring out where they go.
The pic attached shows the ends with blue tape on them. Any clue as to their destination?
PARTSTASH: www.partstash.com
1980 931
1991 Japanese Classic Mini
2000 740i
2006 530xi Wagon
Eliza
PostPosted: Thu Jan 06, 2022 3:04 pm    Post subject: Reply with quote
Not sure if this helps. This original vac line routing diagram was supplied by Smoothie who used to be a major asset on this forum a few years ago, only he had an S2 car.
I can't help by looking on mine as it's not only S2 but also RoW.
For what it's worth, see if you can work with this at all:
https://www.flickr.com/photos/9754161@N02/738844049/in/album-72157600685471748/
Good luck,
Eliza
1985 924 NA RoW
1981 931 S2 RoW
