MikeDanger
Posted: Wed Dec 29, 2021 2:51 pm Post subject: Rear head area oil leak |
I have a bit of leakage coming from the back of the head. can't exactly tell where as the Distributor housing had a full coating of oil and dirt.
What are the usual leakage points? The joint between the Dist and the housing looked wet, but theres no O-ring on these.
I think I replaced the Valve cover gaskets? _________________ It was either this or a giant box of legos |
Posted: Wed Dec 29, 2021 10:21 pm Post subject: |
Ah, so many spots - not the best part of the design. Yes, the back corners of the valve cover gasket is possible, also the distributor housing as it bolts to the head... but also the distributor itself where it slips into that housing, should have a round paper gasket that's pretty weak. But the biggest most likely is the oil pressure sender port... since it's under pressure, unlike all the rest (excepting crankcase pressure)... _________________ Vaughan Scott
Joined: 08 Jun 2010 Posts: 1228 Location: Maysville, Colorado
Posted: Wed Dec 29, 2021 11:39 pm Post subject: |
Agreed. I have had to remove it, clean the threads and reinstall. Permatex makes a Hydraulic/Pneumatic sealant that works well on the threads. It takes a spray cleaner also. Its a copy of some stuff made by 3M and Locktite. Traveling so not sure but it might be #8514. Take a wrench of the right size(17mm?) and cut it down to about 3" long. Its not a fun job. One time I just took the distributor out and mad it much easier. _________________ Mike
'67 MG Midget Dp
Joined: 10 Dec 2006 Posts: 946 Location: Noosa Heads QLD Australia
Posted: Thu Dec 30, 2021 11:43 pm Post subject: |
Agree with the gents above. Just pull the dissy and seal everything unless you can definitively identify where the leak is. _________________ 80/81 932/8 ROW |
Posted: Fri Dec 31, 2021 3:38 am Post subject: |
I've had a leak straight out of the oil sender spade _________________ 1980 931 since 1989
MikeDanger
Posted: Sat Jan 01, 2022 7:33 am Post subject: |
I used some grey rtv on the distributor, but i dont see how to get to, the OPS cant even get my hand back there _________________ It was either this or a giant box of legos |
