Boost Pressure Control Switch - in '90 931
Gatornapper
PostPosted: Mon Dec 06, 2021 11:40 am    Post subject: Boost Pressure Control Switch - in '90 931 Reply with quote
While I totally understand how this switch works (Haynes manual, p.121, #7), I cannot find anywhere that tells me what it does and how it does it.
HOW does it control boost pressure electrically? I thought the waste gate did that...........
Can anyone explain that to me?
TIA,
GN
PostPosted: Tue Dec 07, 2021 5:28 am    Post subject: Reply with quote
Cuts the earth for the fuel pump relay........now no fuel to continue the overboost.
Gatornapper
PostPosted: Tue Dec 07, 2021 9:53 pm    Post subject: Reply with quote
Thanks! Have schematic now. See that.
Haynes manual says switch is N.O. until it sees 15 psi. Not true. Switch is N.C. and opens at 21 psi. My switch is N.C.
So what is a "K27/26 3257 6.10 hybrid turbo"? Enquiring minds want to know....
GN
PostPosted: Wed Dec 08, 2021 12:12 am    Post subject: Reply with quote
Well it can be found here but also in a lot of other threads. If you are relatively new here, its one of the most interesting and coolest builds you will find and the turbo itself comes from another epic car (sadly no more) from Morghen, the GTSwanabe. The link to when the hybrid turbo was installed in CarreraRSR's CS
https://www.924board.org/viewtopic.php?t=34690&postdays=0&postorder=asc&start=465
Edit: What I want to know is when FastEddie hits 20-25PSI, what happens?
The only thing I ever witnessed with this switch is a car being dead because the wire fell off. I should know by now to look first there whenever the car dies or doesn't start
PostPosted: Wed Dec 08, 2021 12:42 am    Post subject: Reply with quote
When my overboost switch failed/not earthed it allowed the car to run but next to no power to drive it as the pump was not running. Others have not been able to start the motor.
Turbo shenanigans .......... its a long and winding path of education and confusion. After 11yrs of ownership and modification, I still don't know all there is to know. Time google searching this forum is your friend. Your questions will not new and will have been asked and answered numerous times here already
Gatornapper
PostPosted: Thu Dec 09, 2021 8:17 am    Post subject: Reply with quote
RSR -
Gotcha on the Google searches before asking questions here.
GN
PostPosted: Mon Dec 13, 2021 4:13 am    Post subject: Reply with quote
Gatornapper wrote:
RSR -
GN
That wasn't a pointed statement to find your own info. It was a polite suggestion to read lots of threads. I've forgotten far more than I have retained from this forum
