fuel injector lines
Rags
PostPosted: Tue Dec 17, 2019 12:16 am    Post subject: fuel injector lines Reply with quote
im looking for some info ,im going to rebuild my fuel distributor on my 79 924,my question is there are some small plastic strainers in it and one large one,i here they cannot be found,so someone on line said do away with them ,thier not needed,that sounds not too good,but i really dont know,also i need new injector lines ,the ones i have have very small diameter openings ,is this the norm or can i replace with a larger size ,again not alot of info on these subjects
Jim d
PostPosted: Mon Jul 26, 2021 9:42 pm    Post subject: Reply with quote
There are four small filters on the outlet of the distributor. I found replacement from k-jet specialist. There is also one big one inside. I never found a replacement so be careful not to break it.
PostPosted: Mon Jul 26, 2021 11:32 pm    Post subject: Reply with quote
I took the screens out of my V8 distributor and have had no problems..
The injector lines are sized purposely, if they are stock..
