gml
Joined: 04 Mar 2021 Posts: 117 Location: Ontario Canada
Posted: Tue May 11, 2021 1:57 pm Post subject: Replacement transmission mount bolts |
Hey all, the fuel tank removal on my 924 is well underway. I removed the transmission this weekend. (I even managed to get the plastic tube out without breaking it). But when I removed the bolts on the mounts and vibration dampers, I noticed they were cracked. Images: https://imgur.com/a/M0139Bg
I found the part numbers and the washers in the catalog. Do you all recommend sourcing OEM bolts, or can I use any hex-head M10 x 25 bolt? The thread is unspecified, which seems like a possible problem. All the stores in Ontario are in lockdown so I have to order everything online. I could just order straight from Pelican Parts but I don't want to pay $50 in shipping and customs for $15 worth of bolts.
I also see there are two washers on the original bolts, but only one washer listed in the catalog. How do I find the second washer, if it matters? _________________ George
1982 924 NA 5-speed |
safe
Posted: Tue May 11, 2021 11:56 pm Post subject: |
I don't think they are cracked, but are supposed to look like that with a "missing piece". They also taper a bit to make them not cross thread as easy. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
gml
Posted: Wed May 12, 2021 12:05 am Post subject: |
Oh, that's interesting. I had a weird feeling because they both looked like almost perfect ΒΌ circles cut out of the bolt, but they didn't look perfect enough to be factory to me.
For what its worth, it looks like the replacement bolt on Pelican Parts don't have that cut out. Pulled the part numbers from Illustration 312-00 in the 924 80-85 catalog.
N 010 254 6 - Hexagon-head bolt M 10 X 25
N 010 254 F - Hexagon-head bolt M 10 X 25
(Very annoying, the bolt images appear in my cart and on searching the part number but not on the actual product details page, these are the images I can see from the cart)
safe
Posted: Wed May 12, 2021 12:11 am Post subject: |
If both looks the same its a good inication that they are supposed to be like that. Also the looks to still be the goldish plating till on the threads and cut out.
The cut out would help with clearing out any debris from the treads and also fix minor damage to the threads. _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
gml
Posted: Wed May 12, 2021 4:29 am Post subject: |
Appreciate the advice. I will clean up and reuse my bolts with the cut out chunks. _________________ George
Posted: Wed May 12, 2021 11:32 pm Post subject: |
Agree, those bolts look great. _________________ Toofah King Bad
Rewaaj
Joined: 15 Feb 2023 Posts: 1 Location: usa, wa, seattle
Posted: Wed Sep 27, 2023 2:40 am Post subject: |
Regarding the transmission mount bolts, you could go with OEM if available, but for M10 x 25 hex-head bolts, you should be fine with a good hardware store option |
