ted von Kampen
Joined: 14 Oct 2016 Posts: 183 Location: Scottsbluff, Nebraska
Posted: Mon Jul 06, 2020 9:05 am Post subject: Plastic used for 924 windshield washer fluid |
| Does anyone know the type of Plastic used to produce this windshield washer fluid container. I have some leaks in mine and I need to plastic weld the leak but I need the correct plastic type to get the correct welding rod. Thanks |
safe
Posted: Thu Jul 09, 2020 12:38 am Post subject: Re: Plastic used for 924 windshield washer fluid |
| ted von Kampen wrote: | | Does anyone know the type of Plastic used to produce this windshield washer fluid container. I have some leaks in mine and I need to plastic weld the leak but I need the correct plastic type to get the correct welding rod. Thanks |
There is usually a stamp somewhere on plastic stuff saying things like PP or PE.
Maybe there is somewhere on the container where you can scavenge some material? |
ted von Kampen
Posted: Thu Jul 09, 2020 12:47 am Post subject: Plastic material |
| Thanks for your answer. I have given the tank a through look over and it does not have that coding marked on it. I am thinking since this was made back in 1981, recycling and the need for the mark had not yet occurred. |
