1980 931 European vs US
doolie72
PostPosted: Mon Jan 27, 2020 3:39 pm    Post subject: 1980 931 European vs US Reply with quote
Can anyone clarify where the extra power comes from in a 1980 European spec 931? I’ve searched around and discovered that for 1980 the compression ratio was 7.5 for both euro and US, so assuming it might be down to one of all of the following:
Timing (for higher octane fuels)
Boost
Lack of catalytic converter?
Thanks
bureau13
PostPosted: Tue Jan 28, 2020 12:36 am    Post subject: Re: 1980 931 European vs US Reply with quote
My understanding is that the bulk of it is due to increased boost, but I don't know that they didn't make other changes at the same time. They may well have pulled some timing to make that increased boost safer?
Boost
Thanks
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
PostPosted: Tue Jan 28, 2020 1:29 am    Post subject: Re: 1980 931 European vs US Reply with quote
Boost
Thanks
Incorrect. The boost is the same. It’s a combo of compression ratio, turbo and ignition differences. 7bhp on paper does not reflect on the road that it’s quicker. Just delivers power differently to series 1. Not one or the other is better or worse. Just different.
PostPosted: Tue Jan 28, 2020 2:15 am    Post subject: Reply with quote
Steve, i think you are mixing up the s1 s2 thread with this us vs row discussion
Its both boost and timing, and also the cat if course. So pretty easy to get it back up to row specifications
bureau13
PostPosted: Tue Jan 28, 2020 7:17 am    Post subject: Re: 1980 931 European vs US Reply with quote
Unless everything I've read about it is wrong, the Euro car made ~10 psi and the US version was closer to 6. That's a significant difference.
Boost
Thanks
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Tue Jan 28, 2020 8:10 am    Post subject: Reply with quote
Yep. You are right. Travelling Germany and posting on the fly
PostPosted: Wed Mar 11, 2020 2:16 am    Post subject: Reply with quote
Sorry so late to this topic.... This I know for sure since I have one
1980 USA has the larger 2664 Compressor wheel and smaller 4.10 Turbine housing. (1981 and '82 USA received the 2660 with 4.10)
Pretty sure the Euro 1980 had the small 'old school design' 2470 Compressor and larger 6.10 turbine housing.
I know its been said its easy to find the 2664 here in USA but not so much anymore. It was only 1980.
