924 NA Head Gasket Crushed Height
joewest
PostPosted: Thu Dec 20, 2018 7:42 am    Post subject: 924 NA Head Gasket Crushed Height Reply with quote
Hey Gents,
Does anyone have the dimension of the crushed thickness of the stock sized Victor-Reinz composite head gasket?
I am doing displacement calcs on my engine as I prepare to add an M62 and am considering not using the Cometic sitting on my shelf that crushes down to .051" due to the state of the block's deck surface roughness and high estimated CR.
Thanks!
'79 924 Supercharged / Track Prepared
'80 931 Daily Driver - Sold
"The number of posts in my profile may represent the number of times I have screwed something up...and admitted it here."
safe
PostPosted: Thu Dec 20, 2018 6:14 pm    Post subject: Reply with quote
I'm in the thought process of something similar.
I have no clue about the crushed height, but the stock gasket is 1.7 mm and according to some calculations I did a 1 mm of change adds/removes about 0.7 to the compression.
If it compresses a couple of tenths or not it doesn't really affect the compression that much...
poor-sche
PostPosted: Fri Dec 21, 2018 4:12 am    Post subject: Reply with quote
See if this helps...
http://garage.ideola.com/top-DL-CompressionRatioCalc.html
It's a link to a compression ratio calculator on Ideola's old site that still works; well at least for now.
joewest
PostPosted: Fri Dec 21, 2018 4:43 am    Post subject: Reply with quote
It defaults to .046", but that is not proof enough that this is correct. I have a spare gasket that I am going to install, torque down with the head and then remove and measure. If I was not so hasty in throwing out the old one I removed I would have had my answer. But alas....
I am keeping a photo journal of the build here if there is interest...
https://photos.app.goo.gl/Mua2zeV8zLs5DUgE9
safe
PostPosted: Fri Dec 21, 2018 5:10 am    Post subject: Reply with quote
Yes!
What throttle body are you using?
I'm looking for something bigger (than stock) and can accommodate a TPS. Preferably bolt on or easy to make an adaptor.
joewest
PostPosted: Fri Dec 21, 2018 5:28 am    Post subject: Reply with quote
I am using a Weber/Redline 60mm assembly. It was a direct bolt-on with no mods to the intake manifold. Also, the inlet accommodates a 3" diameter ROUND hose which is readily available.
PostPosted: Fri Dec 21, 2018 11:45 pm    Post subject: Reply with quote
My actual figures are at home and I'm in Mexico, but as I recall I found quite a bit of variation across the crushed head gasket but if i recall correctly the thickness was in the range of .056 to .062 and I used about .060 for the average. Hope this helps.
Mike
'67 MG Midget Dp
safe
PostPosted: Fri Dec 21, 2018 11:59 pm    Post subject: Reply with quote
And the difference between "under crush" and "post crush" ?
joewest
PostPosted: Sat Dec 22, 2018 3:15 am    Post subject: Reply with quote
Thanks for the feedback gents.
I installed a gasket, torqued it down and then took the head off and measured the gasket again (at the fire rings, each cylinder bore, each quadrant). Cold motor, reused factory bolts, dry, torqued to specs.
Part Description: Victor-Reinz 93110433706 Head Gasket
Out of the box:
Height = 2.0mm (0.078")
Bore Diameter = 89.2mm (3.512")
Installed and Removed:
Height = 1.98mm (0.078")
These tolerances are beyond my concern with this build, so I am using 2mm, with a bore of 89.2mm yielding 12.5cc static per cylinder. That delta in height is only about 0.1cc which is not a concern for me.
joewest
PostPosted: Sat Dec 22, 2018 4:41 am    Post subject: Reply with quote
There is a Weber/Redline TB on ebay now....
https://www.ebay.com/itm/60cfl-Performance-Weber-Throttle-Body-Redline-VW-Type-3-4-Volkswagen-Manifold/283272310411?epid=21026189687&hash=item41f4586e8b:g:ufYAAOSwQZdb9LhH:rk:1:pf:1&frcectupt=true
