Email: nickmail@btinternet.com
Date: 17 Mar 2000
Time: 16:23:56I have an 1980 125bhp 5 sp
the distributor coil went open circuit after the engine got hot, and cut out for an hour.
While trying to find the cause I replaced the bosch? ignition unit down by the headlamp with
one from a METRO (Lucas) from my scrap tins of odds an ends'. after consulting withe the local motorist shop's ignition parts manuals, I connected it to the Porsche and it worked first go! (well after getting my HTs back in the right order)
Unfortunately, the fault persisted, and it was only after replacing the coil as well that I did a test...
While the ignition was dead (usually for an hour) I quickly removed the distributor, and ran the base under a cold tap to cool it off. thenI replaced it (having lined up my timing by scratches made). It cured the problem-so I realised it must be the distributor!!
I had Lucas replace it for £40 and it cured it
