MuteM
Posted: Fri Sep 07, 2018 7:55 am Post subject: About rear spring plate. |
Hi guys,
Question about rear spring plate.
On my 924 1979, I have two different spring plates.
So it should be?
 _________________ 924 1979 |
Posted: Sat Sep 08, 2018 1:46 am Post subject: |
Both sides should look like the two on the left. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
KDJones2000
Posted: Sat Sep 08, 2018 3:52 pm Post subject: |
The '76 cars had a rear suspension setup that didn't allow for ride height adjustment without reindexing the torsion bars.
Cars built after that had spring plates such that you could do some height adjustment with an eccentric bolt attached between the pivot point and the full spring plate.
It looks like you have one plate from a '76, and another plate from a later car.
Since yours is a '79, both should be 2-piece, like the one on the left as mentioned above. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
MuteM
Posted: Sun Sep 09, 2018 4:02 am Post subject: |
| KDJones2000 wrote: | The '76 cars had a rear suspension setup that didn't allow for ride height adjustment without reindexing the torsion bars.
Since yours is a '79, both should be 2-piece, like the one on the left as mentioned above. |
Thanks a lot. _________________ 924 1979 |
