Posted: Mon Aug 14, 2017 2:12 pm Post subject: Installing Motor |
Finally got the street car motor reworked and getting ready to reinstall it. I am putting it in thru the top. How many of the bolt ons can I put on ie, alternator, starter, motor mount arms manifolds, etc prior to installation in the engine bay? _________________ Mike
'67 MG Midget Dp
Posted: Tue Aug 15, 2017 12:48 am Post subject: |
You can have the entire motor intact, minus the front of engine coolant stuff and the CIS components. If this is an NA motor, I would leave the downpipe off and install that later from underneath. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Aug 15, 2017 3:40 am Post subject: |
Thanks, I hoped for that. I'm doing this under much less than ideal conditions, a very leaky shed with a broken cement floor(no concrete) so I need to make it as easy as possible. Also using my generator for lighting. _________________ Mike
'67 MG Midget Dp
