Need advice: Radiator Fan Replacement
pmcaya2
PostPosted: Wed Apr 12, 2017 5:18 am    Post subject: Need advice: Radiator Fan Replacement Reply with quote
I have a bad fan motor in one of the 2 fans on my '82 924 NA. I'm pulling the shroud/fans now and would appreciate advice from anyone who's "been there & done that".
I'm not finding a specific 924 fan, but there are some generic replacements - including shrouds with 2 fans at a fairly reasonable cost . Or replace the bad fan with a generic fan in the existing shroud. Also it might be possible to attach the existing blades to a new motor as an option.
Thanks in advance for comments and recommendations.
Ozzie
PostPosted: Wed Apr 12, 2017 7:16 am    Post subject: Reply with quote
A genuine fan is costly here (may be nla now) so I bought a generic fan from the local car shop the same size and fitted to the shroud
I still had overheating problems so attached another to the front and set to run continuous with ign on. (I live in the tropics)
Its AUTO and its BLACK
Montego Black on black/red
Kenodog
PostPosted: Wed Apr 12, 2017 7:30 am    Post subject: Reply with quote
I have about 5 shrouds and countless fans. PM me if you are interested either.
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
v8carreragts
PostPosted: Wed Apr 12, 2017 11:13 am    Post subject: Reply with quote
I have a v8 conversion and use a 944 turbo radiator and radiator fans. So far I have not had cooling problems.
I wouldn't think it would be too much trouble to use 944 fans and shroud on a 924. The 944 radiator is about 2" taller but the fans are 6 blade and slightly larger in diameter so you would get more airflow. There are lots of 944 fan assemblies on e-bay.
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze
snakoil
PostPosted: Wed Apr 12, 2017 9:07 pm    Post subject: Reply with quote
I got a generic cheap ebay slim replacement fan 3 years ago
While I haven't used the car that much, installing the fan was uber easy.
Fan is still working today without any issues.
I replaced the entire 2 fan shroud with a single fan the heigh of the rad hooked up to the standard alternator wiring.
1979 924 NA
