Quick Release Hub Question
PostPosted: Mon Jul 18, 2016 10:57 am    Post subject: Quick Release Hub Question Reply with quote
Being a total dummy on some things. Do I get a Quick release hub to fit the the approximately 5/8" Threaded section pf the steering column or the under 3/4" spline?
Mike
'67 MG Midget Dp
PostPosted: Mon Jul 18, 2016 9:55 pm    Post subject: Reply with quote
Depends how you do it.
We welded on an extension (sleeved onto the main column) which went to 3/4" IIRC, so then welded the hex on that.
The nice, but spendy, way to do it is an adapter that bolts on in place of the stock splined hub, specifically for Porsche.
If you weld an adapter directly on the stock steering column shaft, I think you'll find the wheel is too close to the dash...
PostPosted: Mon Jul 18, 2016 10:52 pm    Post subject: Reply with quote
I wish it were a bit easier. On my street car I have a standard Grant Performance GT wheel that gives about a 2-1/2" offset from the end of the column. I am small person with very short legs so I run the stock seat as forward as possible and the clutch is still just a bit of a stretch at times. Secondly, the entire stock dash is long gone so I have to build a new one anyway.
So, I guess the method is to get a seat and plant it where wanted for the legs, realizing I could extend the pedals but don't really want to. Then place the wheel. Then after the cage is in with a cross bar just above the steering column, build a dash.
Mike
'67 MG Midget Dp
PostPosted: Mon Jul 18, 2016 11:44 pm    Post subject: Reply with quote
Yes, definitely.
PostPosted: Tue Jul 19, 2016 3:25 am    Post subject: Reply with quote
Thank you for the advice.
Mike
'67 MG Midget Dp
PostPosted: Tue Jul 19, 2016 9:37 pm    Post subject: Reply with quote
NP, anytime...
