Glemon
Posted: Fri May 06, 2016 12:07 pm Post subject: Door Card Removal |
I have found more than one set of instructions, I have done this before on other cars, but I am stuck but good on this one. The inside door handle, all the instruction say to just pry the sucker out. Well I have tried a big screwdriver and a flat trim removal fork, it comes out somewhat, but does not pop out. The door cards and trim are one of the few good things on the car and I would like to preserve them.
The ultimate goal is to replace the passenger window and remove the electric side mirrors for paint.
Is there a trick or pressure point, anyone have a pic of one removed so I can see where it clips on?
Was hoping to orime it on Saturday, soending way too mych time on this tonight.....81 924 if it matters. _________________ 88 924S
68 TR250
02 IS300 |
Glemon
Posted: Fri May 06, 2016 12:22 pm Post subject: |
Took one more shot, the little inner smooth piece is separate and comes off first. On to the fun part. _________________ 88 924S
68 TR250
02 IS300 |
Glemon
Posted: Fri May 06, 2016 11:14 pm Post subject: |
Mirrors off, new window in, that was fun, sure I would get better with practice (or three hands) but getting the window back on both tracks was kind of a bithch, worked better when I raised the mechanism and trid starting the slides towards the front instead of the back. _________________ 88 924S
68 TR250
02 IS300 |
XLR8
Joined: 30 Mar 2016 Posts: 150 Location: Byron Bay, Australia
Posted: Sat May 07, 2016 7:18 am Post subject: |
One gets quite good at door panels after a while! _________________ '81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100 |
ronjeds
Joined: 04 Sep 2006 Posts: 54 Location: Powder Springs, Georgia USA
Posted: Sat May 07, 2016 7:47 am Post subject: |
Here is a shot of the Driver's door panel from an '88 924S. The 10 clip positions are in the same locations on the passenger panel. Once you've removed the hardware (door release, arm rest, lock button, mirror adjustment bezel, etc.), pop loose the 10 clips (preferably with an interior tool) and then move the panel vertically to disengage it from the window slot in the door.
https://www.flickr.com/photos/137376438@N02/26252024134/in/dateposted-public/ _________________ Ron
1988 924S Special Edition |
Glemon
Posted: Sat May 07, 2016 12:30 pm Post subject: |
I will have to pull the left one to wire the mirror back up, should go smoother with the experince and the tips. _________________ 88 924S
68 TR250
02 IS300 |
