Retro fitting trans from S2 into S1 ?
Kenodog
PostPosted: Sun Oct 30, 2016 9:36 am    Post subject: Retro fitting trans from S2 into S1 ? Reply with quote
So I have the opportunity to purchase an S1 equipped with a snail shell LSD. Question is, will the torque tube bolt directly to the back of the bell housing or is it a different length ? ( I know I will have to swap the torsion bar carrier etc. at the rear of the car.) The reason I ask is because I have a trick 911 aluminum pressure plate that I would like to use but I'm pretty sure it only fits into an S2 bell housing...
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Shurick
PostPosted: Mon Oct 31, 2016 6:34 am    Post subject: Reply with quote
You can use the whole TT and gearbox stuff from S1 on S2 without any issue if you'll swap the torsion bar carrier. The only difference between the S1 and S2 castings I've being able to see was the crank sensor mounting surface.
WBR, Shurick
'86 924S -- R.I.P.
